Hotstar on WebOs 3.3.4 and Firmware 05.50.95
5 answers to this question
17 hours ago, Mithun Kankal said:
Hotstar is not visible under content store on webos tv version 3.3.4 and firmware 05.50.95.
can you please tell how i can install hotstar on it?
AFAIK hotstar is available on tvs with WebOS 3.5 and above only.
So no way to install it.
8 hours ago, Mithun Kankal said:
@Karan Batra
Can it be possible to update WebOS version from 3.3 to 3.5?
Can you please provide details stepl for it?
If steps are not available then WebOS team should check on it as lot of customer would want it.
Yes Lg team and lg management works only on upcoming models . They have great reputation but future lg market will fall no updates on old versions so far I bought 3 lg smart TVs this time I will change mine and opinion of others .
@Karan Batra
No its not possible. Since your WebOS is already outdated kind off, Its better to get an external device like fire tv stick or mi stick or airtel xstream box. You will have a host of options.
Just get an external device, why take unnecessary stress when a 2000₹ device can solve all your problems. Its with all OS, support is discontinued sooner or later. Netflix recently stopped supporting a series of Samsung TVs and Sony as well.
  • Thanks 1
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
