How do I extend the memory of my LG web on TV?
I have boought a USB memory stick but unfortunately I still cannot use this storage to benefit the TV's running of apps. Any certified LG solutions? as USB memory stick doesn't even seem to record with the quality I would expect 😕
Posted (edited)
@Kane The memory of a smart TV cannot be upgraded or extended like  a PC, it is a completetely different and closed hardware architecture. If you want to use the "Time Machine II" program recording function, you will need to use something at LEAST 64GB capacity, plugged into the USB port. You will find a 1TB Seagate Hard Disk (or similar make) USB3 spec will work well for recording programs, even HD. The socket with the blue centre is usually the USB3 socket, that is the fastest, best spec.  I have mine tied to the TV bracket with a cable tie (never let it dangle from the cable only). You need to connect it and let the Time Machine function detect it, and "format" it to its requirements. Note that the TV only has to be plugged in and on standby, for scheduled recordings to work, it does not need to be ON, it only turns on the disk and the tuner in standby 1 minute before the scheduled time (screen will be off).
Edited by td47
typo
    • By andystaffs
      Just bought a new LG 43UT91006LA TV .
      After one week we're getting a "short of memory " screen warning before TV shuts off and restarts . I've not loaded any apps but I've managed now to delete one . I've checked that the apps are updated . I'm thinking that I can rid myself if the games but not sure how to do this ..I'm a bit baffled that a one week old TV can't cope with it's pre- installed apps ?!
    • By ironmonkey
      Just bought an LGLED-65UJ630 65INCH TV. Right away I started to get the message "This app will now restart to free up more memory". After searching the internet and forums, I now understand that this problem is huge, it has been going on for years now and it is right across many models of LG TV's.
      I have tried everything to fix this problem. It has the latest firmware. I did the factory reset and that lasted 4 hours before I got the message back. I turn off the TV and leave it for 10 minutes, maybe one hour later I get the message. I delete browsing history, maybe 10 minutes and I get the message..... you get the message.
      As I understand it, the problem is that LG TV's don't have enough internal memory, but they have shipped a ton of their "smart" TV's with this problem.
      My question is, has anybody heard anything from anybody, anywhere about a solution to this problem. I really want to keep this TV, but it is not fit for purpose in this state.
    • By Puja aingh
      Respected LG TEAM
           KINDLY SHORT OUT MY LG WEBOS LED TV MODEL NO IS 33LK628BPTF MY ISSUE IS EVERY TIME RESTART MY TV BECAUSE I OPEN ANY APP AND WATCH ANYTHING SUDDENLY RESTART MY TV AND SHOW FREE UP YOUR STORAGE AND RESTART YOUR SYSTEM      HOW CAN I FREE UP MY SPACE  PLEASE SOLVE MY PROBLEM
    • By Tanni
      My Lg TV which has the smart functions and magic remote is playing up.
      I often use web browser or you tube or similar apps to watch videos etc.
      Recently however, it keeps crashing and displays a message to the effect that the memory in the app is low or it need to close to free up more memory?
      My TV is less then 2 years old and is doing this. I love the telly and the smart features especially the web browser function, however this recent issue is making me think about the longevity of such LG smart TVs and whether I should've spent a few hundred more and got another telly.
      Please can someone advise what I can do to fix this as it takes away the whole point of smart TV.
