All4 App on LG Smart TV
4 answers to this question
Posted (edited)
@Hinderslyne I se a lot of complaints about this Channel 4 app. It seems to have a lot of trouble handling advert transitions to and from the viewing program. I see that too sometimes with other apps here in OZ. It is possible that their CDN (Content Delivery Network) servers are struggling. Best thing would be for you to log in to that Channel 4 site, and decribe your issues,how many times it happens per day, and what effect it has on your viewing pleasure. The more complaints, the quicker it gets fixed.
Check your network though: Are you using WiFi or LAN internet connection? If WiFi, is it 5GhZ or 2.4GhZ band? Does the signal strength look good on a phone using the same WiFi band as the TV, when you are near the TV?
Edited by td47
typo
Hi @Hinderslyne
I agree about the more complaints the better, but you need to complain directly to Channel 4 as it is unlikely that they read this User-to-User forum.  I find a good move to get a corporation's attention is to use Twitter, that way the entire world can see there is a problem and chime in as well.
    • By Will M
    • By Lesbo
    • By Rex G
    • By Mogens
      Kind regards
      Mogens
