7 answers to this question
@Christonian Is the issue on any channel, only specific ones (e.g. HD).  Is it more so with animated films?
First, have you got any extra devices attached (e.g. BD/DVD player, AV amp [AVR], or TV cable box via the AV AMP into the TV eARC HDMI). If so, are ALL of those devices connected via good quality cable that cover HDMI 2.0 or 2.0a (often quoted as 2.1)?  Lower quality ones can be a loose fit and have connection or internal crimp issues.
Second, have you checked that you have the latest firmware update in that TV. I see that the latest might be 04.80.03 depending on your region (copied from AVFORUMS, user post dfa937)?
 If no joy with any of the above, I would get it checked or replaced under warrantee.
FIRMWARE INFO: "- 04.80.03 - KR, US, EU, June 2020
  • OFFICIAL CHANGE LOG: Apple AirPlay function improvement - (the rest of changes mentioned below are UNOFFICIAL, extracted from the firmware itself)
  • WebOS version updated to v4.8.0-52203
  • The device codec capability configuration for the EAC3 codec changed from 6 channels to 8 channels.
  • The device codec capability configuration (EDID) for the LPCM codec changed from 2 channels to 8 channels, so the 2019 models can Pass-Trough multi-channel PCM audio via eARC ---- this firmware update has a bug which causes eARC to incorrectly mark multi-channel PCM sample rates - rendering some AVRs/Soundbars mute
  • The list of CA certificates was updated.
  • Media server 8K video playback support added.
  • The max size of the saved EPG data was increased (size of the volume increased by 10MB).
  • Airplay application was added to the list of apps that are kept alive.
  • Built-In App-Updates:
  • WebOS Browser App (Chromium) updated (internal version didn't change).
  • LG Advertisement App updated.
  • Firmware updates of the following modules:
  • WIFI
  • Audio DSP
  • HDMI 2.1
@td47
It has updated itself a few times since buying so I would assume it is up to date on all options
I was using netflix through the TV so no cable issues plus just upgraded them just in case before this to 2.1 48 gbps cables so when I get PS5 I will be able to take full advantage of it
Using my TV as the main hub and only outputting Earc to AVR for dolby
Seems to do it on everything like PS4, Switch, Plex and Netflix/Disney/Prime etc so not internet issues as when I game it is just single player games no internet needed
@Christonian Thanks for confirmation.I just spotted this on another forum for LG C9 flickering/flashing bright:
"Its related to the « Logo Luminance » setting...just turn it off and you will be ok".  I do NOT have a C9, so cannot verify that, but it is worth a go. Others said it fixed the issue.
that seemed to work for a few episodes and then started flickering again about 1-2 hrs of use
Posted (edited)
@Christonian Interesting that it fixed it for a bit. Sounds a bit like software/firmware IMHO. I would contact LG support directly to see if they know if it is a known issue with the C9 and that firmware update. I think I have seen other complaints about B7 and C9 flickering. Push the issue and insist on a replacement under warrantee if they try to fob you off.
Edited by td47
Typo
    • By OliverRC
      Dominating With Over 52.4 Percent Market Share in 2024,
      Company Reinforces Its Unrivaled Leadership in Premium TVs
      SEOUL, March 12, 2025 — LG Electronics (LG) has reaffirmed its dominance in the premium TV market, leading global OLED TV shipments in 2024 with over 52.4 percent of the market share. For 12 consecutive years, LG has commanded the global OLED TV market, continually enhancing the TV experience with audiovisual excellence and AI-powered personalization, embodying the true essence of OLED technology with perfect black levels and enhanced brightness.
      According to market research firm Omdia, LG secured the top spot in the global OLED TV market last year, shipping an impressive 3.18 million OLED TV units. Notably, fourth-quarter shipments alone surpassed 1.1 million units, showcasing the company’s ability to deliver cutting-edge technology that meets evolving consumer preferences.
      OLED TVs accounted for 45 percent of the premium TV market in 2023, based on models priced at USD 1,500 and above, marking an 8.5 percentage point increase from the previous year. With the market expected to exceed 50 percent this year, LG is committed to driving innovation and maintaining its leadership in the OLED TV industry.
      As demand for larger screens continues to rise, the number of ultra-large OLED TV shipments has also increased, comprising 16 percent of the entire OLED TV market. LG remains at the forefront, dominating the market with a 57.5 percent share in 2024 for OLED screens of 75 inches and above, including a compelling selection of 77-inch, 83-inch, 88-inch and 97-inch models.
      Backed by over a decade of OLED innovation, LG is set to introduce its latest OLED TVs, featuring advancements like wireless transmission of audio and visual content up to 4K 144Hz with no latency or loss in quality, AI-powered personalization through webOS, and superior picture quality with enhanced brightness and perfect black levels for a truly exceptional viewing experience.
      Global TV shipments reached 208.8 million units last year, marking a return to growth after three years, with OLED TV shipments rising 8 percent year-on-year to 6.07 million units. Additionally, LG’s total TV shipments across both OLED and LCD models reached 22.6 million units last year, representing 16.1 percent of global TV market revenue.
      Have you ever wondered how many LG OLED TVs are shipped every year? 100 thousand units perhaps, maybe as much as a million? In the first half of 2023, LG recorded over 1.33 million shipments of its stunning OLED TVs, setting new benchmarks and records its competitors can only dream of.
      link hidden, please login to view, LG captured over 55 percent of the global OLED TV market in the first six months based on total shipments. As a renowned OLED TV leader now celebrating 10 years of innovation in this space, LG has once again defended its premium TV crown while further cementing LG OLED TV’s status as the pinnacle of premium TVs.
      The “bigger the better” trend continues to prevail in the TV market, which is great news for LG. As more and more people desire larger TVs for their living spaces, models of 75 inches or larger accounted for a remarkable 11.4 percent share of total OLED TVs sold, while shipments’ yearly average growth rate topped 90 percent over the past five years. Staying on top of this growing trend, LG is resuming its dominance in the market with an outstanding 64.2 percent share in total shipments of OLED TVs over 75 inches.
      LG is targeting this new demand for large and premium TVs in the second half of 2023 with the groundbreaking TV (model 97M3) it unveiled in July, which boasts the world’s first 4K 120Hz wireless solution that makes it easy for customers to achieve their dream interior.
      Not one to be confined, LG unleashed a tidal wave of 10 million TV units (OLED and LCD) on the world, which has helped the company carve out a 16.2 percent share of revenue for itself in the global TV market.
      Despite facing a downturn in the global TV market, LG persisted in strengthening its inventory management and securing higher profits while actively pursuing a strategic approach for its premium and ultra-large displays. And this commitment has paid off substantially, with its LG OLED TVs now accounting for around 30 percent of the company’s overall revenue generated from TV sets.
      TV shipments totaled over 92 million units in the first half of 2023, matching last year’s first half performance. The OLED TV segment, which has been led by LG for a number of years, has already passed the 2 million shipments mark this year, which bodes well for the rest of 2023.
      OLED TVs are continuing their takeover of the global TV market after capturing 9.3 percent of all revenue in the first half. Meanwhile, Omdia predicts that OLED TVs are set to shine even brighter, projecting at least a 43 percent revenue share among premium TVs priced above USD 1,500.
      Find all the latest news on the home entertainment business and learn more about its world-leading innovations on the LG Newsroom.
      LG’s New OLED evo Exemplifies Visual Perfection With Striking Brilliance and
      Unrivaled Blacks, Along With AI Personalization for a Tailored User Experience
      SEOUL, Jan. 5, 2025 — LG Electronics (LG) today unveiled its 2025 OLED evo lineup, highlighting a range of advanced TV offerings, including the world’s first true wireless OLED evo M5, and OLED evo G5 models. With LG’s latest α (Alpha) 11 AI processor Gen21 at its core, the latest OLED evo models present unparalleled OLED picture quality with impeccable blacks, exceptional brightness and advanced processing capabilities. Powered by AI-driven personalization, the LG OLED evo offers a customized experience tailored to each user and showcases the pinnacle of OLED innovation for an elevated home entertainment experience.
      The latest OLED evo TVs feature LG’s upgraded Brightness Booster Ultimate technology, which enhances light control architecture and light-boosting algorithms to achieve brightness three times higher2 than conventional OLED models. This significant boost in brightness brings fine details into focus across different brightness levels, resulting in a more vibrant and lifelike viewing experience.
      LG OLED evo refines every detail to perfection with flawless blacks, accurate color reproduction and stable performance. The latest models achieve top-notch black levels in both bright and dark settings, producing vibrant and accurate colors. These advanced OLED displays have received UL Solutions’ “Perfect Black”, “Perfect Color” verification and are certified by Intertek for 100 percent color fidelity. The 2025 OLED evo TVs also boast rapid brightness and color temperature stabilization, earning TÜV Rheinland’s “Quick Stability with Image Quality” certification.3 This ensures users experience exceptional picture quality immediately upon powering on the TV.
      New for 2025, LG’s latest OLED evo 4K TVs support Filmmaker Mode® with Ambient Light Compensation4 – an advanced version of Filmmaker Mode developed in collaboration with the creative community. This feature accurately detects the lighting conditions of the viewing environment and automatically adjusts the picture settings to maintain the filmmaker’s original intent, delivering a truly cinematic experience in various lighting conditions.
      Elevating its reputation as the ultimate choice for gamers, the latest LG OLED evo TVs boast several features tailored to gaming, including the industry’s first 4K 165Hz5 Variable Refresh Rate (VRR), certified by NVIDIA® G-SYNC® and AMD FreeSync Premium. The OLED evo models enhance gaming with tear-free, stutter-free gameplay, minimal input lag and up to 165 frames per second. The OLED evo TVs are the first to receive ClearMR 10000 certification by VESA, ensuring flawless motion and seamless experiences even during fast-paced action sequences.
      Powered by the advanced Alpha 11 AI Processor Gen2, the 2025 OLED evo models provide enhanced picture and sound quality. Deep learning algorithms meticulously analyze and refine low-resolution and low-quality images, enhancing them to a higher definition with pixel-level precision for natural and sharper visuals. Additionally, Dynamic Tone Mapping Professional offers expert-level control over HDR10 content for professional creators, allowing precise customization and fine-tuning of images for accurate color and detail representation in all viewing environments.
      Complementing the impressive visuals, AI Sound Pro delivers rich, immersive audio with virtual 11.1.2 channels of surround sound, adjusting the tonal balance and clarity for an immersive, tailored listening experience. Designed with personalization in mind, LG’s newest OLED TVs boast AI-powered features that understand and adapt to individual audio and visual preferences. By analyzing over 1.6 billion image settings and 40 million sound profiles, the AI Picture/Sound Wizard tailors audio and visual modes for each user, ensuring a truly customized entertainment experience. These AI-driven features represent a new level of smart TV innovation, making the 2025 OLED evo models the most intuitive and user-centric TVs on the market.
      The user experience is further elevated with a personalized journey that begins the moment the TV is powered on, courtesy of the AI Remote. AI Welcome greets users by name and provides tailored recommendations based on their preferences and viewing habits, while AI Voice ID adds convenience by recognizing individual voices, automatically switching profiles and delivering content suggestions that match personal tastes. Finding content on LG’s newest OLED evo TVs has never been easier, with AI Search6 leveraging a Large Language Model (LLM) to understand conversational context and uncover subtle user intentions. Access to Microsoft Copilot further streamlines the process, allowing users to efficiently find and organize complex information using contextual cues. For an even smoother and more engaging experience, the AI Chatbot proactively identifies potential user challenges and offers timely, effective solutions. What’s more, the Generative Image Gallery7 allows users to create custom backgrounds using voice commands, adding a personal and creative touch to the viewing experience.
      OLED evo’s user-friendly webOS interface provides a personalized and streamlined experience to access content and settings more easily. The new home screen is faster, more convenient and increasingly personalized with enhanced UI and categories. Additionally, webOS now supports multi-platform integration with the Home Hub, seamlessly connecting with multi ecosystems, ThinQ and Google Home, for control of various IoT devices. By bringing together these versatile ecosystems and broadening cross-platform capabilities, users can effortlessly manage and control their smart home ecosystem through a single, intuitive interface on their LG’s latest smart TVs. Extending benefits beyond the initial purchase, the webOS Re:New program allows LG Smart TV owners enjoy the most up-to-date TV experience for the next five years.
      LG has presented the first-ever OLED TV capable of transferring audio and video wirelessly, transforming the home entertainment experience with unmatched audiovisual performance. As the world’s first true wireless OLED TV, the latest M5 series delivers wireless audio and video transmission at up to 144Hz8 without latency or loss in picture and sound quality. Certified by NVIDIA G-SYNC®, this wireless OLED TV ensures a tear-free, stutter-free gaming experience, even during fast-paced action at 4K 144Hz.  Building on this innovation, LG has extended its advanced wireless audiovisual technology to QNED TVs, bringing its core value of technological excellence and cutting-edge innovation to more customers.
      LG’s OLED evo models have been recognized for their customer value and performance improvement, earning multiple awards including the CES 2025 Best of Innovation Award (for 83G5 models) and the Honoree title (83M5 model) in the Video Display category.
      Visitors to CES 2025 will have the opportunity to explore how LG is elevating the home entertainment experience with its latest innovations from January 7-10 at the company’s booth (#15004, Las Vegas Convention Center). To stay up to date with all of LG’s announcements at CES, visit website and LG Global YouTube channel.
      1 Equipped on G5 and M5 series.
      2 Applies to 65/55/77/83-inch G5/M5 models, compared to the same sizes of conventional OLED models (B5 series) with a 10% window.
      3 65-inch M5/G5/C5 series model has received this certification.
      4 This feature works on models equipped with a light sensor.
      5 4K 165Hz VRR is available on 55/65/77/83-inch G-series models.
      6 Available in US and Korean market at the initial launch.
      7 Available in US,UK and Korean  markets at the initial launch.
      8 Wireless transmission refers to the transferring of video and audio signals between a TV screen and the Zero Connect Box. Visually lossless, based on internal test results with ISO/IEC 29170-2 and measurement results may vary depending on connection status.
    • By Nihar Ranjan Dash
      The international content on JioCinema and Hotstar apps are not playing. No issues with Indian content in Hindi or other regional languages. But English, Korean, and Japanese content are not playing. Specifically, I want to play Disney content on Hotstar and HBO content on JioCinema App.
      I tried resetting all configurations and reinstalling the applications and re-logging into the apps. Still, the issue persists. I tried switching off the TV and tried pressing the power button for complete discharge and rebooting my router, but the same issue persists.
      **I found a workaround though, changing the wifi network or using a mobile hotspot on TV and then all content plays well even if I revert to my primary Airtel wifi, It still plays. but the next day the same issue continues.
      It's an overhead to switch the wifi every time I want to watch Hollywood titles. Certainly, it's not the experience I want with a TV of a hefty price tag. No other devices (Mac, ios, android, windows, Android TV) have this problem. Also, it's not the wifi issue, as I can watch the same titles on other devices. The LG TV also doesn't have the capability to remember a few WiFi networks to ease this workaround of switching networks.
      Alas, Nobody informed me about this issue earlier while making the purchase. Now such pricey TVs shouldn't have these issues at all. Kindly let me know If there is a permanent fix for this issue.
