Remove or not start with LiveTV
By starwoodtech
By Chris Schults
I live in netherlands so I have all in dutch on LG. But there are some big tiles on the screen (see image) Thuiskantoor Game Muziek etc.
I do not use them and want to get rid of them. But I can not find anywhere in users guide How to do that. They appeared after last updat of WebOS.
Greetings
Chris
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
By Renver
When i power on my OLED55C8PLA TV it always starts at the source 'SET UP BOX' even there is no set up box connected. We only use HDMI2. That is also always the used source when we power down the TV. Its quite anoying the TV doesnt starts the input last used.
I hope someone can help me with this issue!
Thanks!
By Extra Celestial
Would love to auto start the Alexa app so my smart home can connect to it automatically when I turn it on from a plug since you can't turn on the tv with the hubs.
One small workaround instead of trying to figure out how to turn on the tv from a hub since it disconnects from the wifi when it powers off.
- 2 answers
- 25,211 views
- 12 replies
- 23,885 views
Andrew Robinson
We recently got a new LG 43" TV for our bedroom (43UN7300AUD). There are no inputs for this TV as we only want to use it for streaming services (Netflix and Amazon). There is no Antenna hooked up to the TV either since we don't want to watch LiveTV on it (the only Antenna we have is hooked up in our family room to a FireTV Recast, not to a smartTV).
When we turn on the TV it auto-tunes to channel 2-0. Since there is no antenna, this is just loud snow. Even when we go to the dashboard, it defaults to showing liveTV and hence more snow & noise. Even though the LG TV stations are enabled and working it will always tune to 2-0 when I turn the TV on. I've tried going through the menu and cannot find any setting to change this. I'd be happy removing or disabling "LiveTV" as an option and would love it to start with the dashboard with LiveTV not expanded/active. Even clicking on the amazon prime button takes time and we get several seconds of the snow before the smart features startup.
With more and more people only using streaming services, I have to believe the TV supports our use case and should not try to ever use liveTV.
Is there a setting I missed in the menu to stop it from always trying to go to liveTV when I turn the TV on? Or at the very least make it tune to an LG channel on start to avoid the snow?
Update: of course, right after posting thisI did find that you can use the amazon prime button on the remote to turn the TV on. I still would like to fix the dashboard playing snow and would prefer to have the TV not try to use liveTV if I use the power button to turn the TV on.
Thank you
Edited by Andrew RobinsonFound a work-around
4 answers to this question
