Wireles Keyboard doesn't work in youtube App
By Horniak
By CJ Catalano
By Lee Magee
By JRay
Ricardo27
Hi guys,
I bought a K600 logitech keyboard knowing it is supported in Web OS 3.5 and higher. It works on Netflix and web browser but not in Youtube app.
I am really frustrated, being able to search in youtube from my keyboard was my main goal with this purchase.
Regards
