trphilip Posted October 3, 2020 Posted October 3, 2020 Hi, I am from India ,using LGWEB OS TV UH6030. This tv dosent have hotstar and voot apps. help me to install them. Quote
1 George Hofmeister Posted October 5, 2020 Posted October 5, 2020 Hi @trphilip I believe that HOTSTAR only support TVs with webOS 3.5 and above, your model from the factory had version 3.0 so unless it has received an Over-the-Air upgrade you are not going to be available. The decision not to support earlier models was HOTSTAR's and there is unfortunately nothing LG can do about this. As for voot as yet I do not think they have produced an app for the webOS platform, so you would need to as them via customer support or via their social media feeds when they are planning on producing one. 1 Quote
0 trphilip Posted October 5, 2020 Author Posted October 5, 2020 @George Hofmeister thanks for ur reply....pls guide me if there is any way to upgrade the software version ... Quote
0 George Hofmeister Posted October 8, 2020 Posted October 8, 2020 On 10/5/2020 at 10:06 AM, trphilip said: @George Hofmeister thanks for ur reply....pls guide me if there is any way to upgrade the software version ... Hi @trphilip Unfortunately is there is not a newer version available either via Over-The-Air or via download at the support page at https://www.lg.com/in to a newer version of webOS then I am afraid you are stuck with the version you have. Quote
0 teja4721 Posted November 3, 2020 Posted November 3, 2020 @George Hofmeister voot is available on webos but if i remember correctly only for webos 4.5 + devices. 1 Quote
0 teja4721 Posted November 3, 2020 Posted November 3, 2020 @trphilip Hotstar is available only for webos 3.5+ tvs. I mailed hotstar team many times to support atleast 3.0 but they are not working on it. They say it is because of technical limitations on webos 3.0 1 Quote
trphilip
5 answers to this question
