@Michiel Romme The initial password for LG Signage Control manager is 1105, but some OEM designs or added software layers might change it, and lock further changes to it. I assume you purchased a used item, and want to change something? What model is it? If you need to "get into it" and change stuff/settings, etc, try a factory/default settings (from user settings -> general I think).
    • By JayDee
      With so few apps available, I find the need to use the janky included browser. It's bad enough but having to type in my account AND password every time? I love that the apps I *can* download work great -- even when I'm at the end of my data plan and everything is hampered by the slower speed!
      You'd think something called "WebOS" would work with.. the web... a little more reliably. Let us download JioPages, OpenBrowser, SOMETHING that makes our TVs easier to use.
    • By Francisco Estrada
      I have the LG WP401 webOS Box model, to configure it, the previous administrator gave it a password and it did not leave it for me.
      How can I give it a factory reset or change the current password to be able to enter via the Web, to use the content manager and control manager
      Thanks for the help
    • By Sterium
      Hello everyone,
      When change the WiFi to other WiFi lost previous one.
      Every WiFi change I have to enter the password!
      It's normal this behaviour?
      TV oled 55c2
    • By Julius Jarmalavičius
      What is the real way to password protect LG WEB OS. If i set password my kids are grown enough to google and use master password to reset the password. is there a way to change master password or some other way?
    • Solution For That Pollution
    • By coyote
      OLED65C1AUB is my first OLED and first UHD TV.
      Is there a way to copy-and-paste my (very long) WiFi password?  (I'm imagining connecting a USB with the password in a text file.  I'd rather not use WPS.  The TV is connected via Ethernet, but I also want my phone to connect.
      So many questions but I start with this probably futile one.
