Smart DNS & ITV hub
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
Tony Levy
I have with the help of this forum been able to get my smart DNS working and can no watch streaming from the BBCi player, and All4 however I cannot get the ITV hub to work, it loads the program I want to watch but then reverts to a screen saying
'Where is my show etc' and it doesnt play
I do not understand why ITV hub will not work yet the BBCi player and All4 and Both work
My5 also does not work but I get the error message you must be in the UK to view this content
10 answers to this question
