Red cursor has suddenly disappeared
I have an LGOLED55C8 TV and this afternoon I turned the TV on but the red cursor has disappeared I have tried all the recommendations but cannot get the red cursor to come back on. My LG Magic remote is model number MR18BA
Does anybody know what to do to restore the cursor please
6 answers to this question
@Tony Levy Most of the "magic remotes" use 2 different technologies to support the buttons. Some use regular "IR" (Infra-Red) like standard remotes, while other buttons (like the HOME button, and the ballistic "red cursor") use Bluetooth (like a wireless PC Mouse).
Test that your Bluetooth functionality is working on the TV side by pressing the Home button. If it works OK, and you can select your TV APPS with the left and right, then the Bluetooth side is working, and the issue is likely to be the remote itself, possibly the ballistic motion detector "chip" inside it.
If the Home button does NOT work, check out how to Re-Pair the remote with the TV Bluetooth. Try this if pairing is the issue:
Many thanks much appreciated
I am beginning to suspect its the actual remote that has become faulty as when I take the power lead out of the plug socket wait 15 seconds and plug back in the red cursor is working however it is not working as it usually does and then this morning after the TV being in standby mode all the the red cursor was not working again. I turned the TV off from the plug socket and when I switched back on the cursor was working.
@Tony Levy That is interesting that a power off makes it work again. When the remote cursor function is failing, does the HOME button still work? Can you also select your different APPS (e.g. YouTube, or Netflix etc)?  If thos are also failing, then the Bluetooth Module in the TV is failing in some way, or drops the "pairing" after the TV goes into standby. Some users are posting that some LG TV models suffer from this little internal combo (Bluetooth & WiFi) module can get too warm, and drops the pairing of the remote. Is there anything under the TV (such as an AV amplifier etc.) that might make the issue worse, with heat rising INTO the TV above it?
Hi Yes home button still works as does Netflix although on Friday night was watching Emily in Paris and it was buffering badly but last night it was fine on Netflix and Amazon prime but cursor was not working. Just turned on my TV and cursor is not working again Home button is working  and Netflix is working.
I have a sonos system in a compartment underneath the TV but that has been there since I put the TV on the unit over 18 months ago, its very strange and very annoying.
Do you think the remote is failing? I have changed the batteries but its made no difference, have just turned thge TV off from the plug waiting 15 seconds plugged back in and turned on and cursor is working again
@Tony Levy It sounds more like the TV to be honest. Check if you have had a recent software (WEBOS or firmware) update recently. Also, if you have a "quickstart" option set or active, turn it off and recheck the issue.
My LG UJ752T -49inches tv after 4years my tv cursor and Bluetooth , wifi everything gets off doesn't work at all, tv was working fine , I bought a new remote also bu then still it's not working , need your support and resolve the problem
    • By leodavid
      I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
      The buttons work fine but for some reason, I can't get the cursor to appear on screen.
      Appreciate the help. Thanks
    • By bos2prov
      I have a LG Model  #55UQ7570PUJ TV. I've set it up so that it loads to my Roku.
      When I press the Input button on my remote, there used to be six tiles that appeared at the bottom -- Home Dashboard, Live TV, LG Channels, Sling TV, HDMI 1, HDMI 2. I have Sling TV as an app inside Roku, but I used to also be able to get into it directly as an Input from the tile at the bottom, and I kind of liked doing it that way.
      I started using LG Channels for a bit, and when I came out of that I noticed that the Sling TV tile had disappeared. I'm not sure if the two things are related, but this is what I have now. Any idea what could have happened and how I get it back?
    • By Smartboy
      Before I buy this very nice LG TV with WebOS 23, my wife and I were using an old samsung with an android TV box. So it is very difficult to adapt to the cursor / pointer. I read the documentation and found it is possible to press the direction buttons to momentarely remove the cursor (which is painfull to navigate for us). But each time I press one of the home, return, wheel buttons,  then you know what, the pointer is back on the screen. I read the documentation from A to Z and didn't find any parameter to permanently DISABLE the pointer ... Any workaround or parameter that I missed ?
    • By Dimmy
      All of a sudden I am unable to cast from my Windows 11 laptop to my OLED65CX TV. The only option given to me is to cancel the request. I've previous been able to cast without issues.
      Any fixes for this issue? Useless LG support agent told me to just use an HDMI cable and kept referring to the TV as a 'monitor'.
    • By Packard8
      Hi Folks, I recently bought an LG 65C3 OLED. When first set up, the on screen pointer was visible, now it has disappeared. Under setings>pointer options are grayed out (deactivated). Is there a way to recover it short of resetting everything to the default state? Thanks
