OLED65E7P update?
By mean2
By OliverRC
By Ajothen
By Roy Brown
By Batman
- 5 answers
- 10,615 views
- 2 answers
- 7,526 views
- 3,101 views
- 1 reply
- 4,793 views
Roadrunner99
OLED65E7P bought in USA but later converted to India region by following the below link
Current software version is 05.80.15
It won't find any new updates while checking from TV menu.
Should I upgrade it to 05.80.55 by downloading from LG India website?
starfish-dvb-secured-m16p-611.dunggir.m16p-61114-05.80.55-prodkey_usb_V3_SECURED.epk
Reason for asking is sometimes the apps act funny, especially Hotstar app seems buggy or not quick to respond. Does work ok most of the time.
Thanks for any helpful advice.
4 answers to this question
