People usually convert the ringtone sound at which part of the iphone phone
That confused me and didn't know how to fix it. Everybody
Can you help me?
    • By woof
      I have a couple of LG OLEDs in shared spaces, with external speakers, one via optical and the other via analog jack (confusingly named headphones). Whenever bluetooth headphones are used and then disconnected, the TV reverts to "internal" terrible audio. For non-technical people this is permanent. Do I have to train everyone to select the device from the long list or can I set a default?
    • By starwoodtech
    • By starwoodtech
      I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
      Does anyone know what it would take to set this?
    • By Ozzie T
      We have a 65UM7300AUE with software version 05.40.10. We have a Google TV dongle plugged into the HDMI 1 port and that is the input we use most of the time. Until recently every time we would turn the TV on it would default to HDMI 1 and the Google TV home screen would be the first thing we’d see. Life was good. Several weeks ago that changed and now the LG OS (I assume) home screen is the first thing we see. Then we have to use the LG remote to select HDMI 1 each time. We never used to have to do this or use the LG remote at all. Kind of annoying. We think we have HDMI 1 chosen as our default input but it doesn’t seem to matter. Any ideas on how we get things back to the way they used to be with the TV defaulting to HDMI 1 automatically?
    • By Renver
      When i power on my OLED55C8PLA TV it always starts at the source 'SET UP BOX' even there is no set up box connected. We only use HDMI2. That is also always the used source when we power down the TV. Its quite anoying the TV doesnt starts the input last used.
      I hope someone can help me with this issue!
      Thanks!
