Hi Team,
By when we can expect Voot Select app for LG WebOS.
As discussed with VootSelect Team, they have sent the app for review to LG. Kindly let us know by when LG is going to release Voot Select.
PFA.
6 hours ago, Bhavan Kamble said:
Hi Team,
PFA.
Hi @Bhavan Kamble
Unfortunately this is a User-to-User forum, so we have no control over when an app submitted by any content provider to LG would be made available for the webOS platform.
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
    • By tarakdave
    • By AtWitsEnd696
