Missing App
By Lleuadwen
Hi, I hope someone can help. I recently bought this TV but can’t find the Art Gallery app that is supposed to be part of the Home Screen. I have searched in apps but only third party art gallery style apps show. What am I missing here?
By Flavio_S
By techguy noob
My LG TV model number 32LM560BPTC is having an issue where the Sun NXT app is no longer available on the LG Content Store. I was able to watch it before, but starting yesterday, the app disappeared. However, on my other OLED LG TV, the Sun NXT app is still available in the LG Content Store. Is this issue specific to the 32LM560BPTC model TVs?
Sarath
By toopie28
Hi can someone help please.
Not sure what else to try.
Thanks!
By Kayaem M
The LG Content Store is missing from my smart TV so I can’t add any apps. It’s an older smart TV and the ribbon does not look like the newer models. Is it hidden somewhere?
Rudish
I could not find Zee5, Voot and Discovery plus apps?
Anybody guide me..
4 answers to this question
