Can i get android app emulator in lgwebos tv. So that i can use all apk apps in webos. Or google chrome with all plugins. That also supports web emulator. I feels this will be useful
Android emulator on WebOS? Not sure there is any available at this stage but why not get an Android based TV instead? Problem solved.
  • 3 weeks later...
    • By coyote
      I'm surprised by how few Settings there are.  Is there an Android Settings App?
    • By Ayon Mondal
      Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN.  Please solve the issue as soon as possible and let me know how to fix it.  This is the serial number of my TV :- 64387205122152TRFLJL
    • By SGray
    • By swattt
      Dobrý den,
      Při sledování Smart TV LG s android boxemTesla se mi často vypíná obraz (problikne) a v rohu se objeví HDR. Nevím si rady v TV to nejde zakázat tak už opravdu nevím?? Kabel?? Mohl by mi prosim někdo dát někdo poradit co s tím?? Děkuji.
    • By Hùng Mạnh
      Hi everyone,
      I was trying to install an environment to develop.
      But I can't run the emulator (Version 5).
      I always get this error prompt.
      Please help me. Thank you.
