Can I install My Player on my LG TV?
TV Model UM7780
Year 2019
If it's not in the LG Store then likely you can't.
But why do you need MX player? The native in-built player works quite well.
    • By wallyricks
    • By MNHL
    • By Nishant singh
      Hi Team
    • By Matt Moran
      Matt
    • By Kemal Sözüner
      I recently bought a LG TV with WebOS version 8.1 and have a frustrating issue.
      I have a usb disk with all my family photos & videos archive in it.
      We love to browse through the pictures and videos on big screen.
      But current LG TV media player displays either pictures or videos. I want to see them in the order they were captured.
      It would be great to enable this feature when "Photos & Videos" filter is selected.
