Hopefully more people will see this solution to an old problem if I start this new thread,rather than just replying and getting tacked on to another thread where many are seeking a solution.
The  problem of " Wired Lan cable disconnected- Wired cable connected" is a simple fix.
First go to settings scroll down to General-scroll down to Home/Store mode and change to Store Mode. Then when Store Mode screen displays go again to settings and again to General scroll all the way down till you reach "Store Mode Settings" you will then see an option to "Turn Off Notifications" turn it off exit and turn TV back to "Home" and no more annoying messages in the upper corner of your TV.
I am assuming this action will also turn off notifications for updates to apps etc. but it is an easy enough thing to check them once in awhile for any possible updates.
Initiating this fix is a blessing as far as I am concerned as I was going to dump my LG and buy another brand saved money and sanity. Hope my post helps some of you!
    • By Jaswinder Sandhu
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By u84six
    • By John Nguyen
    • By Harald Dunkel
      The specs for the magic remote promise "Voice Recognition with Intuitive Mouse Like Pointing and Wheel Control". I think that would be nice. The current implementation of scrolling via the wheel on the magic remote is not intuitive. Why would I move my thumb up to pull the text shown on the screen down to the bottom?
      Question is, can we please get natural scrolling for WebOS 5.5.0 and newer? Some option in the settings would be fine. The current "unnatural" scrolling is a major obstacle in usability for me, and the main reason to not buy LG again.
