By
wallyricks
I have owned a couple of LG TVâs over the last 8 years, with the current one being a high-end 77â model.
I am still using LG TV SmartShare (v.33) as my âMedia Playerâ v2.3.1511.1201 for my PCâ which was last updated in 2015 but it is still compatible today. As proof, my latest TV is now 11 months old and I have had zero issue (until you see below).   Â
My PC setup is: Windows 10 Pro (with all latest updates) and a TP-Link Archer BE19000 (BE805) router.   NOTHING has been changed on my router, TV (no updated or changed firmware) or any equipment moved around in the last 4 months.
Up until about 3 weeks ago, everything ran just fine. The SmartShare program was always defaulted to have Sharing ON, upon start of it, which is always when Windows boots). However, about 3 weeks ago, the SmartShare PC program has started to randomly change its status to Sharing OFF. I would then have to go into the program, manually change it to ON and then it works anywhere for 30 minutes up to 20 hours, and again, randomly change the Sharing to OFF.
I am an experienced PC user, and I am very sure that this has nothing to do with my WIFI because itâs not a dropped connection or random TV not being found.  Something is happening inside Windows 10 that is triggering this status change. And it never fluctuates back to Sharing ON by itself.
As an experiment, I installed an alternate Media Server program called Serviio. One can also see that when my Sharing changes to OFF, the two green lights turn red.
Anyone have an idea of what can be happening after nearly 8 years of not experiencing this?      I am guessing that Windows is triggering some âServiceâ to stop running, but what can it be?
Binod Kumar
đ
