Bluetooth Transmitter
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By janisad
I have an LG 32LJ610V TV.
Leddieward84
I am in the UK, i have a 50UN74006LB TV, i would like to connect 2 pairs of Bluetooth headphones, which i know you can't do "as standard".
I have tried the "One for all" Bluetooth transmitter, but it appears not to be compatible with LG devices.
Has anyone had success with such a device?
Thank you
