Very disappointing Ethernet connection on 55NANO796NE
By akhil7j
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
By makem
I have a LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
By Glamma2311
My tv is acting strangely after there was a software update (sometime between April 10-15,2024)
randomly turning off and on -- many times within a few minutes remote works some of the time or only certain buttons goes to a colored screen i.e. purple, yellow, light blue with no image just color sudden annoying continuous, high pitch sound like an alarm Checked and reset the cable box and called cable company.
Unplugged and plugged tv back in.
Change the HDMI input
It is becoming very frustrating.
By Musica napoli live e anteprime
Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
- 3 replies
- 1,459 views
- 3 answers
- 7,378 views
