Random volume decrease
I have a problem with my LG TV. Sometimes when i am watching TV the volume decreases by itself. I don't know what causes this but the only fix is to increase the volume above 15. I have contacted LG support and they changed the TV motherboard but the problem remains. Anyone else having this problem?
Model: 49UK7550PLA
webOS TV Version: 4.2.0-8406 (goldilocks-gomolsha)
Hey!
I'm having exactly the same issue. The sounds gets really low (but the volume setting is unchanged), and I have to go above 15 to reset it at lower levels. It's concerning that replacing the motherboard didn't help, but I sort of always assumed this was a software issue.
    • By joe zx
      I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
      I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
      Any advice, thanks.
    • By Danilo Peixoto Ferreira
      I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
    • By RCarlton
      I have a 2 year old LG smart TV and A LG soundbar. Periodically the volume will drop way down and when I turn the TV off and on it restores to regular volume.  TV or soundbar? Any ideas?
    • By PoeyYong Wong
      I have this LG OLEDXXCXPTA TV with Sonos for over 2 years. Except in the beginning where I have some issue with volume control with Sonos, it has been working fine. Recently I am encountering problem controlling volume with LG remote for my Sonos Arc. The only way I could get it back to work is to reset the LG TV to initial setup like what I have done 2 years + ago to regain volume control back with a new setup.
      However this time it seems to be different, I continue to lose volume control unexpectedly and I cannot see a trend. The latest being when I use the Netflix app to watch shows on my LG TV.
      Any suggest to resolve this?
      It is getting frustrating to keep resetting TV to initial setup so that I could use the remote for volume control.
