KNX / Rasberry Pi / Arduino control of LG WebOS TV
By Regis Wheeler
By JasonB
By matesz
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
By Smartboy
Hi all, I am trying to find a solution to the native but complex "magic" remote control from LG. For elder or young people, this magic remote control with the OLED C3 TV is too complex or too busy (using a lot of unused keys. The new model for remote control is now either the Apple TV RC, the Android TV RC or the Google TV remote control. All these RC are small, easy to use with only 10 to 15 keys instead of the 40 to 50 keys. I saw that. in the past LG introduced smaller remote control (see below the first image LG AN-MR500) but I am not sure it is supported with the LG OLED C3. I also saw that the latest projector CineBeam Q comes with a small new RC (see bellow). This new white RC has only the necessary keys (max 10) and seems to be fine ! Also, the new C4 is coming seoon and I suppose it will include a new Remote Control but we don't know yet what it is ... Do you have an idea to solve my issue ?
