By Fricassee
By Wondering
By FiestaRed
I've been having problems registering my new TV for warranty today. The registration form asked for a 15 character serial number and although mine has two completely different serial numbers, the printed one and the on screen one are different, both only have 12 characters and neither would be accepted.
The TV is a model OLED48A16B
By BUB
2 TVs, one OLED77CXPUA and the other just installed OLED65C2PUA. 77’ shows a program in 2160p while the 65’ shows the same program only in 1080p. Anyone know why ? Thank you.
By Girevik
Hello all,
I recently got a soundbar for my LG TV and have it connected with HDMI ARC on HDMI 2 I do my TV watching with a Firestick. I have this weird issue where if I switch apps on my Firestick using one of the buttons that go to an app, or (sometimes) using voice commands, the switches to the HDMI 2 input. If I choose the app from the menu, it works fine.
I have no clue why how I start an app makes a difference, but is there a way to set the TV to ignore HDMI when it comes to automatically switching inputs? I looked through the settings and thought I figured it out when I turned off instant game response on HDMI 2, but the switch is still happening.
- 0 replies
- 2,099 views
- 6,959 views
- 4 answers
- 4,396 views
- 1 reply
- 7,836 views
michaelbr
I bought an LG 49UK6200PLA in Spain, but on the LG Spanish site, there's no such model listed, how can I register this product? It seems this model is for UK, but for some reason it's also sold in Spain.
