LG Magic remote MR18BA not working
By Roy Brown
By Rex G
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
oscarodas
Magic remote stopped working after tv was taken to a different place, I have reset the tv a few times, remote has new batteries, the method to de-register and register doesn't work, all buttons work except the ones labelled: Netflix, amazon, Live zoom, and the microphone. When i press the microphone button I get the following message: Press OK to register theMagic Remote with your tv, when I do it I get the message: Only specific remote model can be paired.
My tv is an Oled55B6T, and according to LG the magic Remote MR18BA.
If is not possible to get it working I would like to get rid of the annoying message: "Only specific remote model can be paired." It shows up everytime I change channels or do any other funtion like choosing to watch Netflix or Youtube, etc.
3 answers to this question
