**NEW** DAZN question
By Fricassee
By Wondering
By BUB
2 TVs, one OLED77CXPUA and the other just installed OLED65C2PUA. 77’ shows a program in 2160p while the 65’ shows the same program only in 1080p. Anyone know why ? Thank you.
By Girevik
Hello all,
I recently got a soundbar for my LG TV and have it connected with HDMI ARC on HDMI 2 I do my TV watching with a Firestick. I have this weird issue where if I switch apps on my Firestick using one of the buttons that go to an app, or (sometimes) using voice commands, the switches to the HDMI 2 input. If I choose the app from the menu, it works fine.
I have no clue why how I start an app makes a difference, but is there a way to set the TV to ignore HDMI when it comes to automatically switching inputs? I looked through the settings and thought I figured it out when I turned off instant game response on HDMI 2, but the switch is still happening.
By Sabab
Hello. I am from Bangladesh. I have an LG television (LG UP7550 43'' UHD 4K TV). I want to play movies with Bengali Subtitle. My TV isn't showing the Bengali subtitle file (srt or ass) though I have renamed it as the same name as the name of the movie and kept it in the same folder. How can I get rid of the problem? Do I need to use any special player for this purpose? Or is it completely impossible to watch movies with Bengali Sub?
- 0 replies
- 5,942 views
lecouvie
I have an LG TV (about 5 years old) and was able to find and download Amazon Prime app, so i know how to do that. (Don't get me started on LG's account setup - ugh).
However, I cannot find DAZN as an app in Canadian store?
As an alternative, i launch the browser, (internet) and go to the DAZN website and try to watch from there but get an error message.
Any suggestions. as it is driving me crazy.
thanks in advance
norm
4 answers to this question
