@Richard Hollander The LG Smart TV will have its own antenna/cable tuner. and only "knows about" it's own TV GUIDE. The Tivo  set-top-box is a totally seperate box, with its own tuners, and the TV does NOT have access to its tuners, so therefore cannot see the channels it provides. The channels that YOU select on the Tivo box are fed directly to the TV via the HDMI cable, so are treated as an external signal source.
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By RussS
      Russell
    • By Den C
    • By tezz7624
      re tv guide
      used to be arrows to allow viewing of previous programs on catch up but they seemed to have disappeared
      is there a way to make them return
