Recording TV Issue
I've recently bought a
, It has a external powered SSD disk.
Sometimes we'll notice it start to record a scheduled program, then 1 minute later stop recording.  Being as LG tried to avoid paying the license for ITV/CH4/CH5 players here in the UK.
Any idea why?
I've only just bought this TV to replace a 2 year old Philips TV which had no end of hassles, and TBF Smart TV's really are as thick as Pig S....  My old windows 7 media centre PC with TV tuner was so much more reliable and easier to use.
4 answers to this question
Posted (edited)
@Spencer Cook Has recording ever worked properly on the new TV, with that SSD? What was it used for before?  Did you let the new TV format it to ITS requirements?
Edited by td47
typo
This disk worked perfectly fine in previous TV.  It also works fine with this TV, it has been formatted in this tv, and will record fine.
However occasionally the TV will start to record then a minute later stop.
I can then go to the program and start to record and it records the rest of the program fine.  As I say, it's just occasionally it stops recording.
@Spencer Cook It is possible that it is either a minor firmware bug, OR an intermittent SSD disk error, that causes the recording to stop. To eliminate that, take the SSD off the TV, connect it to your laptop or PC, then run the checkdsk command on it. That will be in the "cmd" option (it calls the black window like the old DOS command window.
See how to here;
If no joy, you might need to purchase "Spinrite" that is a very good disk analyser and fixer, that might force it to do a proper "wear levelling" on any off spec memory areas on the SSD. It is around $USD 70, but you get a lifetime licence and support. See here:
    • By Regis Wheeler
    • By Hoghton Jim
      Many thanks.
    • By JasonB
    • By AMK
      Tv model 55UJ630V-TA
      Sw version 06.10.50
    • By StefanosBand
