Hello
I plan on getting the “Alexa Echo Flex so I can control my tv and smart plugs. I have Alexa on my iPhone, and it works great, however I cant turn it on using Alexa. I believe it’s a simple fix, but can’t work it out. Can anyone help? This is on the 65UK6300PLA TV in my front room, where is an app that I have setup.
on my other tv in my bedroom, 43UM7000PLA there is no Alexa app, but I have managed to connect it via my phone Alexa app, again, cant turn on.
I have the LG thinQ app and this doesn’t allow turn on, should it?
edit: also, the 43um7000pla cant find any updates from the LG software check website found here.
    • By Stephen Davies
    • By matesz
    • By Trevin
    • By Citron2010
      Hi,  I have an LG 43UN71006LB with OS v4.50.53 (latest)
      I thought I'd test this on my TV and it works very well.  I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
      Also tried:
      "Alexa, enable Sound Share on LGTV"  - "that command doesn't work on device LGTV"
      Anyone have any ideas?
    • By Sandy8100
      Alexa installed correctly on    32lq63 TV.
      remote that came with to does not appear to have a microphone. How do I control Alexa?
      Simple instructions for a simple person please !
