Confusing pop up message about recording
If I have a recording programmed, I get a pop up message just before it’s about to record..” recording about to start.....Options CANCEL OR OK”
so if I click OK the recording continues, but what if I click CANCEL does this cancel the recording ? Or just cancel / close the pop up window ? If it cancels the recording, the pop up should say “ CANCEL THE RECORDING “
I am sure whoever programmed this message know what it meant and what the options do, but not obvious, to me anyway
thanks
@Arthur Dent This is just a standard "notification", from the Time Machine recording app,that gives you chance to cancel it, in case you decide to watch  it on LIVETV instead. Just ignore it (it goes away after 1 minute), or click the OK.
 Y point was, quite often Canvel on a pop up simply means close this window, but this cancel has a deeper meaning.....it actually cancels the recording ( thanks for confirming that ) just think the pop up should say cancel scheduled recording , mind you there are more ‘odd’ things with the LG OS so maybe shouldn’t worry about this....thanks
    • By Hoghton Jim
      Many thanks.
    • By StefanosBand
    • By Kev999
      I can only get the Reminder facility to work on live TV in the lower channels like 1, 2, 3 etc, but rejects attempts to use with the HD channels at 101, 102 etc.   Is this normal?
    • By Nooneuno
      Our tv always needs to have the recording volume reset... the problem seems to be that the formatted disk has a small boot partition, about 150 mb, plus a 4 GB "main" volume, and the recording app "sees' the boot partition, and won't "hold" the setting for the main volume...
    • Solution For That Pollution
    • By Ron Williams
      I am unable to set a reminder or to set recording of any BBC1 programs on my oled 55a26la tv via Freeview .Anyone else experiencing this fault ?
      is there a fix for this ?
