Overseas Satellite channels
By OhmorrowSouthWales
By Michael Hirons
Can anyone advise me whether this tuner is "generic" or freesat? and i would like advise on using it with a Sky+HD satellite dish.. any advice/help appreciated as im cancelling sky contract soon Michael
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
By leader6234
Hey guys !!!
Thanks in advance !!!
Garel
HI we had our tv set to the last country choice which shows as -- on the options menu on our 55 OLED PLN Model from 2019 however some of the UK apps would not work eg All4 due to not showing the UK as a country. This has lost us the overseas channels we had via Astra and Hotbird I have tried to program manually but have had no luck finding the Polish , German and other european channels that would normally be there. Does anyone know how to solve this or is the OS blind to other channels when set to a specific country? We have a Virgin 360 Box but sometimes want to watch European content but would prefer not to have to add a satellite box as clearly the TV can accept satellite input when set without specific country settings.
Does anyone know a solution or specifically how to set the satellite channels to receive other channels when set to the UK?
