6 answers to this question
@dibbie camacho It should be there by default, you do NOT need to "download it", as extra apps have to COME from there, as THAT is your LG download centre!
Maybe it is not in view, and just needs the app ribbon to be scrolled right to see it (often by clicking on the 3 lines icon one side or the other).
See this for an example:
On 12/29/2020 at 5:15 PM, dibbie camacho said:
My LG Smart TV does not have lg content store, how can I download the content store app to my tv model # is 60pn5700-ua. Thank you.
I have the same problem! I just purchased my 43" 43UN7000PTA smart TV last November and the interface is different from the others.
    • By Will M
    • By Lesbo
    • By Rex G
    • By Mogens
      Kind regards
      Mogens
    • By Annie Yazbeck
      I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
