Hi everyone, i purchased new OLED OLED55CX6LA.
I have two big issues
Ethernet isnt working, It says that the cable Is connected, It obtains ip address, everything Is green in the test Page, but apps cant get internet access, sometimes i can also see directories in the Nas, but cant open any file.
everything works under wifi.
I cant see amy photo under dlna, It says that all directories are empty, nothing seen on Nas or phone connected with thinq app.   Video are shown.
Thats Disappointing for a 1500€ TV.
@Lorenzo Naselli Is your Ethernet LAN cable going DIRECT to your router, or are you using a PLA (Power Line Adaptor), or a SWITCH? Hopefully NOT an old HUB, as those are NOT intelligent with hardware MAC addresses, and use all ports for all packets!! Most switches (e.g D-LINK 1GB Hub) can store 1024 MAC addresses.
Ensure you have the latest Firmware in the TV (03.11.30) in case there is an undocumented item that LG fixed that helps you.
In the meantime, are you saying that connecting the TV to the WiFi works fine? NOTE: some complex APPS (e.g. AirPlay etc.) do NOT have all packets, i.e. Discovery packets, sent from WiFi connections to Ethernet ports, as some routers block those.
Please also let us know your router make and model, it might help.
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By matesz
    • By Brianco
      Hello
      We have an LG55UQ75006LF 2022 model. Until recently we were getting Dolby Atmos on our Creative soundbar. This was via Disney+ as well as numerous clips on YouTube. Now only Dolby Digital plays. We haven't altered any settings, so cannot understand what has happened. There has never been an option for Dolby Atmos in the TV settings, so assume it was some kind of pass through.
      Any advice would be greatly appreciated. Thanks
      LG OLED Brings Back the Works of Kim Whanki to New York in 50 Years with Frieze New York and the Korean Cultural Center New York
    • By Deniss
      After last  13.30.61 update my iptv apps plays just channels for 30 seconds and the pauses. I have used ss iptv app and smart iptv. On my Samsung TV all works fine using the same apps
