Hello. I installed an app on my LG C9 called ArtHola. It is a gallery app that changes chosen artwork on the screen. Unfortunately, LG's fireworks screen saver comes on after a minute. Is there a way to disable that? Or is there a way to make that ArtHola app send a signal to the TV to keep the fireworks from coming on? I know that when I have my Nvidia Shield TV's screensaver come on, the TV never interrupts that.
@eespinosa64 The Shield TV is HDMI cable connected, so the actual TV will be acting differently when that is active, as it will be sending an "active stream" to the TV all the time, even if a static image.  However, when you have a TV APP active in the WebOS, a static artwork image will be detected by the screensaver timer. If you can configure ArtHola to display a changing set of images, that changes each one in just under the minute timer, you might stop the internal screensaver kicking in. If that does not work, reach out to the ArtHola developers on their web-site, to see if they have a suggestion.
Thank you for your reply.  The ArtHola app changes images about every 12 seconds. That is still not enough to keep the internal screensaver for coming on, unfortunately. A simple option on LG's part could have prevented this.
    • By Ajothen
    • By Ajothen
      I wish a nice screesaver with timing settings and types.
    • By rologoetz
      Hi, just bought a new LG OLED and pretty fast noticed that I`ve now chance to change the wallpapers ?!?
      Really pretty strange - even the smallest smartphone offers such a feature. The TV has enough USB interfaces - why is it not able to customize this by an own set of pictures ?
      Can`t be that big rocket science to implement this , especially for such an expensive device this should be a standard feature !!!
      Or did I  miss something in the settings of the TV ?
    • By Itachi3431
      Hi all,
      TV details - 4K Ultra HD Smart LED TV 55UR7500PSC
      P.S., running latest Web OS
    • By Batman
      I have a LG 43QNED756RA AEK Smart TV
      If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
      So I cannot Move or Edit Program Numbers or Delete
      Any help and comments would be appreciated
