Disable "wifi direct"
For some reason, on my TV, random phones have the ability to prompt a pop-up asking if they can connect to my TV via wi-fi direct. This is, obviously, quite annoying while I'm in the middle of using my TV for something.
I've never accepted access for any of these phones, and they're not on my wifi network.
My TV is a 43um7300pu and I'm running 5.00.02, which is the current software.
There appears to be no setting to disable connections via wifi direct in the menus.
Is there anything I can do stop these annoying popups?
3 answers to this question
Posted (edited)
@CatsPaw I do understand your annoyance with this, and also I think this can open up security concerns. I saw some older posts that stated older firmware DID have an option to turn this functionality off, but it has now dissappeared in the UI (settings) on most models.
If you can find the Facebook page or Twitter feed for LG, try commenting/complaining there, AND raise a support ticket with LG in your country. The more owners complain, the better chance you get  of getting that ability in a firware update in the future.
You could quote these links, or research more to find actual TV WiFi direct vulnerabilities to quote to LG support (other owners on here may know of these):
and
Edited by td47
typo
I am running into this too.  I can see my neighbor's LG C1 TV and they can see mine.  I may have accidentally casted to theirs while I was trying to figure out what was going on.  I can't find anyway to disable in the current settings.
    • By mycop
      Greetings.
    • By Tunari
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • Guest
      By Guest
      Things that I've tried:
    • By loafty
      Tv  connects to wifi and can stay connected for couple of days then I will switch tv on and internet (wifi) will be disconnected so go to connect up again and tv can't find any networks so turn off and unplug from power wait 5 to 10 minutes then plug all back in go to wifi settings might be lucky to find my network select and enter password and works again. Only thing is I got a different modem from internet provider and they have told me that the modem is working fine but I have never had an issue like this with tv before. Tv states wifi is turned off but I can't find anywhere that I can turn wifi on in the tv, does anyone know ?? Tried calling LG didn't get much help at all, I am 71 years old and just want my tv working the way it should so hope someone can help. Thanks
