On 1/4/2021 at 3:15 PM, Pramod Bisen said:
Hi Team
By when we can expect Sony LIV app and MX Player availability in LG Smart TV web OS version 5.80.35.
Please reply
Hi @Pramod Bisen
If by Team you think you are talking to LG themselves then you are out of luck as this is a user-to-user forum, and it has no affiliation with LG.
There is now a SonyLiv app available but only for 2018 model year and onwards TVs: https://www.lgwebos.com/topic/5391-sony-liv-app/
As for MX Player are you referring to the media playing app or the Indian streaming service?  Whichever one is concerned  you would need to contact them to see why they have not produced an app for the webOS platform because as a rule of thumb LG to do not produce apps.
    • By Jack1151
    • By wallyricks
    • By MNHL
    • By Prashant Chavan
      Please add Jio TV app in upcoming software update.
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
