HDMI record to usb
By Venkata
Hello Team,
By OliverRC
By hollean
By JamieG
By Kane Murphy
R. Ho.
I am currently viewing my old camcorder tapes on my 2019 smart TV via hdmi.
Does anyone know if its possible to record this to a usb stick using time machine function? Or does it only record tv programme signals?
