2020 LG Smart TV stuck on WebOS 03.10.60
By Roy Brown
By Khelben Arunsun
New and most important apps and updates not available on lg43lj554t smart Tv.
By Dheeraj Sharma,
- jio cinema
- voot
- (and 5 more)
- 1,025 views
DO NOT UPDATE to Version 04.40.25 or 04.40.70 else you will lose Video Playback on the Web Browser on some websites.
By AusRob,
- 0 replies
- 5,046 views
- 2,523 views
- 4,605 views
CrunchyBrunch
Hello everyone, I have this issue with my 49" LG TV (Model number: 49UN71) that has just been stuck on WebOS 03.10.60 with no way to update it to the latest version of WebOS. I don't know if this is normal or not, but I think that it's a bit particular that my 2020 TV is running a firmware update from 2017 with no updates on the horizon. Please leave a comment if you know what I might do in this situation!
