Sync TV sound with Amazon Echo
I've just bought the 2020 LGNANO866 and also an Amazon Echo, which amongst other uses, I wanted to sync with the LG TV in order to have an additional speaker at the rear of the room. So far, my attempts (in the LG 'Sounds' out settings) have enabled the Echo to connect via Blutooth : this gives the TV sound ONLY through the Echo speaker and NO sound through the TV.  The LG rep. I contacted suggested adding the Echo via the 'Surround Sound' setting, which I tried with the result : sound from TV speaker great as normal, but weak, muffled &  'echoey/delayed' sound from the Echo speaker. Attempting to tweak volume and other settings in  Surround Sound made no difference. Awful!
Am I doing something wrong and if so, can someone please show me the right way to achieve something that I (mistakenly thought!) would be relatively easy to achieve?
Stephen.
8 answers to this question
@Stephen Davies To be honest, I think Bluetooth Speakers are OK with  iPhone an iPad users, and other than the Magic Remotes, the Blutooth interface should not be used.
For good TV surround sound, you cannot beat a good AVR.
TBH.....I think you are absolutely right! My Sony AV receiver is now over 20 years old, but in conjunction with my 2 Mission speakers, still produces a great sound...well good enough for me anyway. Unfortunately, all the connections on the Sony receiver are RCA/analogue and whilst I was able to connect to my previous, 8 years old LG TV, things have progressed more digitally, connection-wise these days, so my new TV posed a bit of a hook-up problem. However, I think that I've now got it sorted out by investing in an analogue/toslink/optical audio converter. Digital optical cable from the TV goes into the corresponding input on the converter and then the L & R analogue leads output into the receiver. I don't know whether or not the sound is output in any Dolby configuration, but hey, I've now got some semblance of surround sound. I do realise and appreciate, that to do things properly, I really should invest in a more recent AV receiver with more up-to-date & compatible connections, but I don't want to let things get out of hand, financially.
My next step, when funds allow, is to replace my existing Sony 3D Blu-Ray player (similar 8+ age to my old TV) which I suspect is only equipped with an HDMi 1.4 connection, for a current model 4K UHD compatible (LG UBK90 perhaps?) with HDMi 2.0 or 2.1. I've tried hooking my old player up with the new TV and outputting the sound through the Sony receiver, but there is a noticeable sync mis-match with the sound & vision. As I'm not getting this when I'm watching either live TV or streaming services through the AV system, I suspect the problem might be with the player's HDMi 1.4 port. Will find out in due course......
@Stephen Davies The optical "Toslink" cable  ports limit the decoding possibilities (no ATMOS, Dolby DD etc), and only HDMI does the full range of sound decoding methods.
In any event, you really need a centre speaker to get good dialogue from TV sound. I changed my old Marantz for a Yamaha RX-V385, and although low-end, it gives lots of options to enhance the dialogue, and adjust the "DPL MOVIE" setting and equaliser, to centre and enhance the dialogue. Where some inputs don't always follow proper HDMI-CEC rules (e.g. Foxtel iQ2 box), the "scene" buttons one the Yamaha remote are great for just a one press to get all the settings for specific inputs (press and hold to remember your setting that you did for a particular input device, just one time). Use HDMI ARC or eARC and 2.1 cables to/from TV for best results.
Thanks again for your input. You confirmed my suspicions regarding the Toslink's capabilities, but unfortunately, due to the age of my receiver, I have few choices. As I stated, it doesn't even have a direct optical port (hence having to use an analogue to Toslink adaptor) let alone any HDMi sockets! It comes down to either just listening via the TV's internal speaker and having the benefit of Dolby Atmos, or foregoing that and outputting the sound through the receiver and my two stand-alone speakers.
Of course, the 'sensible' thing to do, would be to just go out and buy a new receiver, equipped with all the latest/current connections & ports and then....no problem! However, I can't really justify that and also, most of the ones I've looked at put out 100w (or more) per channel and my Mission speakers are only recommended for 25-50w pc and although compatible with the modest output of my ancient Sony receiver, might possibly either distort or fry with a unit pushing out more than twice the power, so I'd have to go to the additional expense of replacing my speakers if I upgraded the amp. You see how things escalate......? Additionally, I have no intention (with regards to my room size & layout) having any more than those 2 side/front speakers, so 'proper' surround sound isn't a requirement. I just want a bit more 'presence' to the sound when I'm watching a movie, than is output from just the TV speaker.
As I said, I'm hoping to upgrade to a 'basic' 4K UHD Blu-Ray player soon and quite possibly the LG UBK90 that I mentioned. I still have that analogue connectivity problem to work around, but it does have an optical out port and is equipped with 2 x HDMi ports which would stand me in good stead for the future IF I bit the bullet and bought a new AV receiver.
Fo the moment, with the TV, I've got great UHD vision and just have to compromise on the sound if I want to output it through the existing receiver. It's a trade off that I just have to accept I think. Just can't have it all at the moment!
@Stephen Davies Sure, I know what you mean, you have to watch the spending on luxuries and "boys toys" these days, and job uncertainties. I had to wait until I had retired before getting some half-decent HiFi.
Have you considered a Soundbar? These have improved a lot these days, with the use of modern electronics and firmware/software embedded. I have seen the LG SN4 soundbar advertised on Amazon UK (£175), and $275 at Retrovision Australia, and it has a high star rating. It supports HDMI.
 Hello again T! I did give some serious thought to soundbars, but in the end, decided (at least for the forseeable future) to try and utilise my existing AV receiver/twin speaker set-up. The main reasons for this being : a) buying a soundbar would just make a working (albeit not brilliantly compatible) system redundant,  b) I've got no way of checking if a sub. £200  soundbar would actually sound 'better' than my current AV set-up and lastly,  c)  The crescent-shaped stand on the 49NANO866 does not allow a 89cm soundbar to fit snugly & unobtrusively beneath the TV without it projecting out too much. Just an aesthetic and dimension consideration and not related to sound quality, but something I had to consider nevertheless....
Still think that the £200 (when & if I have it!) will probably be better spent on that 4K UHD Blu-Ray player. What do you think...?
@Stephen Davies The "weakest link" in your setup is still going to be with the sound I am afraid. A modern/new AVR (such as my Yamaha RX-V385, 100 watts peak) states 70 watts across 2 channels, but you can "soft limit" the volume by having your MAX set to say -20DB in the Sound settings, so as not to over-drive your 50W speakers.
You can get 4K and UHD via a FETCH Mighty set-top-box, and watch what you want, but if you get a Blu-Ray player, you will have to rent or purchase, and I think that works out quite expensive over say a 12-month period, versus a one-off FETCH box purchase, and LOTS of choice (extra channel packs at only $6 per month) with 20 or 30 free movies per month (depending on country).
Your 4K UHD will be a GREAT picture, but mediocre sound, and unclear dialogue unless you get at least 3.1 sound and centre speaker.
I do see what you're getting at, T and accept your logic. I'm just trying (somewhat unsuccessfully!) to both rationalise & weigh up all the alternatives that are open to me, financially and practically. It's complicated, as I've attempted to explain....
I do subscribe to 2 movie streaming services, Netflix & Amazon and 4K UHD content is available (at no extra premium)  on the latter, which is great and I've been able to appreciate the leap in quality over my previous LG HD TV. I have quite a library of Blu-Ray & DVD titles, hence my thoughts about upgrading to a 4K UHD model which would comparatively upscale my existing discs and play any future 4K discs that I buy....probably pre-owned off eBay.
I realise that the 'sensible' route will be to invest in a more up-to-date AV receiver in order to fully enjoy the quality of sound that my new TV can produce, but as I've stated previously, there are several factors to consider. Even installing a centre speaker poses some problems. The most compact one (a Yamaha) that I've seen, would intrude  a couple of inches above the bottom edge of the TV. Not ideal! I've really no other  place to site it, so I'm still unable to reconcile the various limitations I'm faced with, with the most suitable route to better overall sound.
    • By informatiko
    • By Pranay Mokida
      All “xboom by will.i.am” Products Feature a More Balanced and Warm xboom Signature Sound
      LG’s New xboom Line Is Empowered by AI Sound, AI Lighting, AI Calibration and RAiDiO.FYI
      SEOUL, Jan. 6, 2025 — LG Electronics (LG) unveiled its new audio product line of Bluetooth speakers and earbuds at CES 2025, created in partnership with multi-platinum musician and tech entrepreneur, will.i.am. This marks the debut of the “xboom by will.i.am” line, following the partnership announcement in early December.
      LG recently appointed will.i.am as the “Experiential Architect” of the LG xboom brand, aiming to establish it as a culture-forward brand that elevates the listening experience to new heights through completely new sound and design values. All “xboom by will.i.am” audio products are professionally tuned by will.i.am, delivering the xboom signature sound – characterized by a more balanced audio profile with warmer tones. The product design is playfully compact and embodies will.i.am’s creative artistry that stems from his life-long experience in pop culture. Leveraging both his extensive experience in understanding what people love and developing technology for creatives, will.i.am fundamentally inspires xboom’s product development, design and brand marketing.
      The “xboom by will.i.am” line boasts a family of smart Bluetooth speakers – the xboom Bounce, Grab and Stage 301 – all fortified with seamless AI capabilities for a next-level listening experience. The xboom speakers conduct AI analysis on the content being played to automatically adjust AI Sound, switching to sound options that accentuate the melody, rhythm, or voice. The AI Lighting feature keeps the speakers’ bar lights pulsing in multicolored sync for added ambiance. AI Calibration allows speakers to instantly recognize their surroundings to fill various indoor or outdoor spaces with ample sound. And for the first time, xboom speakers now feature a dedicated button for users to instantly connect to will.i.am’s RAiDiO.FYI platform to enjoy various infotainment content tailored for each listener by an AI Radio Host.
      Also, users can enjoy their content with amplified sound through the LE Audio Auracast feature that connects multiple xboom units for a seamlessly synchronized audio output. Even without Auracast support on their smartphones, users can enjoy synchronized audio across multiple units with the xboom speaker serving as the master unit. Moreover, users can enjoy the xboom signature sound that is further enhanced by built-in tweeters and full-range units created by Peerless, the Danish premium transducer manufacturer with a legacy of almost 100 years.
      The 2025 audio product line is spearheaded by the xboom Bounce, which combines refined audio quality with stylish aesthetics. It boosts portable sound to a new level with its built-in, up-bouncing passive radiators, dual dome tweeters and track-type woofer. The Bounce is capable of delivering high-frequency stereo with precise highs and an expanded soundstage, surrounding listeners with enhanced clarity and depth. The name “Bounce” comes from its up-bouncing passive radiators that visibly bounce and light up in beat to the music. It incorporates a versatile strap that enables users to hold the speaker securely in one hand, hang it on a hook, or place it on a tabletop. With a water and dust resistance IP67 rating and Military Standard 810G durability, this robust speaker’s built-in battery lasts up to 30 hours.
      The xboom Grab presents an exciting take-anywhere audio experience, pairing powerful sound with a compact, travel-friendly design. Despite its relatively slim size, the Grab manages to pack dual passive radiators positioned on both sides of the speaker for dynamic bass and lively sound. As the name “Grab” suggests, this speaker is perfect to hold in one hand for use on the go. It can be placed in many orientations – standing upright, lying on its side, or securely nestled in the cup holder of a car or camping chair, or even in the water bottle cage of a bicycle. It also comes with versatile straps for securing snugly to the arm or slinging over hooks and handles. With a water and dust resistance IP67 rating and Military Standard 810G durability, the Grab offers up to 20 hours of battery life.
      The xboom Stage 301 is designed for those who love transforming any space into a lively stage – hence the name “Stage.” Optimized for busking, karaoke night, or any sort of indoors or outdoors gathering, the speaker effortlessly fills big spaces with powerful sound. This robust model packs a punch with its 6.5-inch woofer and dual 2.5-inch midrange drivers, providing rich, full-bodied audio. The Stage 301 distinctly features a built-in handle for easy carrying and a clever wedge design that allows flexible positioning for various setups – flat on its base, tilted back, or seated atop a tripod. Highly durable, the xboom Stage 301 has an IPX4 water resistance rating as well as a replaceable battery that lasts up to 11 hours, allowing greater flexibility and uninterrupted listening pleasure.
      The xboom Buds employ lightweight graphene drivers, which are key to delivering pure, well-balanced sound with rich bass. As thin as paper yet strong as steel, graphene improves durability while supporting LG’s Active Noise Canceling technology, providing a more immersive listening experience. Featuring LE Audio Auracast, the Buds enable users to listen to open audio streams in public and permit multiple device connections so that several users can simultaneously enjoy the same audio. Designed for comfort and stability, the ergonomic ear tips adapt to various ear shapes, while the unique ear hook design provides a snug and stable fit on the go. It offers up to 30 hours of listening time with the support of its charging case, as well as IPX4 water resistance that protects against splashing water.
      “Working with renowned tech and lifestyle innovator, LG, opens the door to groundbreaking and dynamic experiences that speak to a broader community of music enthusiasts,” said will.i.am. “By bringing our cutting-edge technology and distinctive creative visions together with LG xboom, we want to foster an iconic culture where people can explore their passion for music with others on a whole new level.”
      “The xboom by will.i.am line marks the beginning of a dynamic, collaborative journey for the xboom brand and will.i.am, and we are more than thrilled to showcase the first fruits of our partnership at this year’s CES,” said Lee Jeong-seok, head of the LG Media Entertainment Solution Company’s audio business division. “Beginning with the new xboom line, we will continuously aim to elevate every aspect of the listening experience.”
      The all-new “xboom by will.i.am” audio products, which will roll out in global markets in 2025, will be on display during CES 2025 from January 7–10 at the LG booth (#15004, Las Vegas Convention Center).
    • By Kane Murphy
      SEOUL, Dec. 10, 2024 — LG Electronics (LG) has announced a partnership with creative artist, multi-platinum musician, and tech entrepreneur, will.i.am, to launch a new line of audio products under the brand “
      link hidden, please login to view.” The partnership aims to transform xboom into a culture-forward brand with an urban aesthetic, providing an all-new audio experience. In this partnership, LG has appointed will.i.am as LG xboom’s “Experiential Architect.” He will play a pivotal role in carving out a new space for xboom in the audio industry. Drawing inspiration from his pop culture and technological know-how, will.i.am will provide strategic counsel for LG xboom’s product development, design and brand marketing. By combining LG’s advanced technologies with will.i.am’s unique insights as a world-renowned music artist and tech entrepreneur, this partnership will infuse LG xboom products with fresh creative aspirations.
      The 2025 line of “xboom by will.i.am” products, including Bluetooth speakers and wireless earbuds will be unveiled at CES 2025. The xboom Buds will be the first product available in the market.
      All “xboom by will.i.am” products bear the mark of will.i.am, who took part in creating LG xboom’s signature sound that boasts a rich bass with a balanced and warm tones. It comes in two distinct modes for listening: one mode provides stimulating sounds that gets you moving with powerful bass while a second mode offers a soothing sound with harmonious tones. The overarching design for LG xboom aims to elevate music enjoyment. Speakers incorporate clever embellishments such as easy-to-hold straps and colorfully interactive lighting that is in sync with the beat of the music being played. Earbuds are designed ergonomically with ear tips and ear hooks for a comfortable fit that also delivers the best sound experience.
      “This launch marks the integration of our wireless earbuds and Bluetooth speakers into one audio brand, LG xboom,” said Lee Jeong-seok, head of LG Media Entertainment Solution Company’s audio business division. “We are thrilled to announce this partnership with will.i.am that will play a critical role in solidifying LG xboom’s new identity.”
      All “xboom by will.i.am” products will be integrated with will.i.am’s RAiDiO.FYI, an AI-powered interactive audio experience, to introduce a new generation of listeners to infotainment. RAiDiO.FYI empowers listeners with unique abilities to immerse, personalize and have a two-way real-time conversation with their favorite topic-based STAiTiONS. This conversational media platform transforms radio as we know it into a new dimension, connecting consumers deeper with the music, talk radio and cultural content they love.
      LG and will.i.am will celebrate this new partnership with product showcases and tech demonstrations at CES 2025 (January 7-10). To know more about “xboom by will.i.am”, please visit .
