No sharing posibility wiht win10 to LG OLED55GX6LA
I have sinds a few weeks a LG OLED55GX6LA and want to share my win10 laptop screen on my TV.
Can't find any sharing possibility for this TV.
I also have installed SmartShare, but this doesn't recongize my LG tv.
It's there for IOS and android.
Can anybody help me.
Thanks very much for all your input.
    • By wallyricks
    • By rami zapi
      Hi all, i have 2018 LG webOS TV UK6540ptd , my tv and laptop both connected to same wifi. when i try connect my laptop for screen share this message come up to LG TV.
      request screen sharing to your tv - Decline  unable to connect for screen share
      my laptop is windoes 10   64 bit
      anyone can help me fix this issue.
    • By Gary C
      Is there a good App for LG so I can share screen from my Android phone?
    • By shelu parmar
      Dear sir ,
      I am not able to screen sharing or mirroring between lg 65uk7500pta and iPhone XR .there is no option available in screen cast for iPhone ,this is premium brand how you can ignore this pls tell me the solution.
    • Solution For That Pollution
    • By Chanti
      Is there any option in LG Web os TV LG Lf6500 to get screen sharing in one touch?
      Or any easy method to use?
