Audio sync loss on high definition live TV after streaming
By mean2
By Roy Brown
By atcronin
By informatiko
By DW1
Colin Todd
After using iPlayer app on my lg nano TV when I tune to BBC 1 be, the audio starts in sync but rapidly goes to several seconds delay .
4 answers to this question
