Aggiornamento a webos4 per tv 32LJ610V per utilizzo Alexa
@Alfonso It seems that only the new ThinQ range is properly compatible with Amazon Alexa devices. See:
Other owners on here with more expertise/knowledge  than me may be able to add to the list, but I suspect you might need a TV with the latest WebOS to use it.
    • By Gal Avraham
      Apparently, some apps no longer run on webOS 3.5.
      Is there a way to upgrade or reinstall firmware and webOS to 4 and later?
      Maybe with a USB or so (i.e. offline)?
      Gal
    • By janisad
      I have an LG 32LJ610V TV.
    • By Trevin
    • By Citron2010
      Hi,  I have an LG 43UN71006LB with OS v4.50.53 (latest)
      I thought I'd test this on my TV and it works very well.  I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
      Also tried:
      "Alexa, enable Sound Share on LGTV"  - "that command doesn't work on device LGTV"
      Anyone have any ideas?
    • By Sandy8100
      Alexa installed correctly on    32lq63 TV.
      remote that came with to does not appear to have a microphone. How do I control Alexa?
      Simple instructions for a simple person please !
