How to disable LG media server??
I have a win10 HTPC with all my media files on it. It's connected via HDMI to my home theatre amp which is connected to my LG tv via HDMI. If I'm watching a local stored movie or listening to my music collection on my HTPC it plays on the home theatre speakers and the TV just acts as a computer monitor. If I'm watching tv the audio is via the internal speakers or connected sound bar.
 Something has happened and now whenever I try to play music the LG tv automatically overides the amp and plays the music through the tv with its media server. How do I disable this function please?? I don't really want the tv to perform any media serving functions.
Figured out what was wrong just not sure why.
I use MediaMonkey as my music library and player and I found a setting in it that was showing LGwebOS as the player. I've certainly never set that option so not sure if the TV webOS did it or if it was maybe my new (google home) smart device.
    • By mycop
      Greetings.
    • By wallyricks
    • By Muser
    • By StanJ
      I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
      On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
      I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off,  HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
      Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
      Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes).  It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
      Company’s ‘Optimism your feed’ Playlist
      Garners 1.2 Billion Views in Just Three Weeks
      SEOUL, June 21, 2024 — LG Electronics (LG) has launched a global social media challenge to amplify its brand promise of ‘Life’s Good’ by encouraging customers worldwide to create and share moments of everyday optimism on their social media feeds. Running across TikTok and Instagram, the challenge encourages participants to foster a more positive environment on their social media feeds by posting optimistic moments and selfies featuring the “ link hidden, please login to view” gesture – a popular symbol among K-pop idols created by forming a mini heart with the index finger and thumb – using the hashtags #Lifesgood and #Optimismyourfeed.
      “LG is committed to delivering on its promise of Life’s Good. This social media challenge aims to uncover and share what Life’s Good means to our customers,” said Kim Hyo-eun, vice president and head of LG’s Brand Management Division. “We believe there is real power in approaching life with an optimistic attitude, and our Optimism your feed campaign’s social media challenge is all about embracing the opportunity to inspire more positive activities in the virtual and real world.”
      The social media challenge is part of LG’s campaign and follows the launch last month of LG’s Optimism your feed playlist – a collection of original content that, when interacted with, will pull more optimistic content into your feed. Created in collaboration with global influencers known for their positive impact, the playlist offers users the opportunity to experience more uplifting and encouraging posts. Within just three weeks of its release on TikTok, YouTube and other social media platforms, the playlist has garnered over 1.2 billion views. It has resonated with viewers worldwide, prompting comments about their eagerness to participate and positively influence their algorithms.
      The social media challenge invites users around the world to join influencers including , , , , and in spreading optimism across social media feeds. In just four days, around 21,000 users have already joined the movement to share their optimistic moments.
      Meanwhile, LG has also launched an offline campaign event called ‘Optimism your day,’ which will run till early July. Continuing from last year, a truck adorned with the company’s ‘Life’s Good’ brand slogan is scheduled to tour the 11 business sites in Korea. The truck features a large LED display that plays ‘Life’s Good’ campaign videos and showcases positivity slogans shared by LG employees worldwide. LG believes in spreading the campaign’s message of optimism to employees as well as the outside world.
      “We are all brand ambassadors of LG,” said CEO William Cho. “If each of us starts brightening our surroundings one step at a time, I believe LG will one day become a company that truly radiates positivity, helping to create better lives and a better world.”
      More details about Life’s Good campaign can be found on the campaign page at .
