Problem with streaming on TV after update to new version 05.30.10
I update MY TV WebOS last night  (Version 05.30.10)), then I cannot stream from my Android phone anymore! It worked perfectly with the pervious version.
Do you know if LG fix it or I should downgrade to the previous version?
How can I downgrade it?
Just turn off the Airplay option that LG recently added, then it works :)
    • By mean2
    • By OliverRC
    • By Ajothen
    • By atcronin
