- 1
LG 49U67V TV internet connection speed issue.
By Regis Wheeler
By JasonB
By akhil7j
By AMK
Tv model 55UJ630V-TA
Sw version 06.10.50
By jcol5786
A few years ago I bought a 43" LG Model 43UK6200PUA, manufactured in 2018. I'm from Canada but I purchased this TV in the US. It was a store demo unit on for a great price. I took it home to Canada, set the location to Canada and setup up in our bedroom. It has been working fine with our Fiber TV service as well as Netflix, Amazon etc. We also to have a 60" LG TV in the living room which was purchased in Canada. This TV is similar in age to the one in the bedroom. Recently I started watching the LG channels on the living room TV. I hadn't really paid much attention to them before but now I enjoy them. My problem is that the LG channels do not work on the bedroom TV. I suspect because it was purchased in the US but located in Canada. With the location set to Canada the LG channel guide populates and shows what's on however when I select a program I get the following message.
- 1 answer
- 620 views
- 0 replies
- 1,046 views
- 3 replies
- 1,331 views
- 803 views
Mak
Hi everyone. I have a LG 49U67V TV.
I updated my internet connection to fiber 100Mbps. My new router uses both 2.4 & 5.0GHz frequencies. With my mobile phone I check my Internet speed with fast.com and it is 100Mbps. My TV connected also via WiFi in the same network can't reach with fast.com more than 12Mbps. What is the problem? Does my TV not support higher speeds?
If I change the router settings to transmit only in the 2.4GHz frequency, would something change? Would I loose speed in other devices such us my laptop and phones?
No can't connect via cable to the router. And I'm afraid to pay 50€ or more for a power connection
I tried something else. I connected my tplink WiFi range extender and then via ethernet cable my TV to this range extender. The problem here is that also the range extender can't reach more than 15 Mbps of speed. I tried to conect my phone to the extender and the result was the same the extender did not achieve more than 15Mbps in fast.com. So the extender had also issues achieving the speed of the ne router
