By Joe C
By JasonB
By Cody LUEN
Hi!
Version: 23.20.36
By hans peter
Previously, my TV (LG32LM6300PLA) worked so that when I turned Power on in my headphones, I got the message Pairing followed by Connected. At the same time I got a button on the screen named Connected (so far I remember) and when I clicked OK on it with my remote control I got rthe sound in my headphones and it disappeard in the TV-set. When I shut off the power in my headphones the sound disappears in them and is back in the TV-set.
Remaining at Settings the soundshift works, i.e. when I turn on the power on the headphones I get sound in them and when I turn the power off it disappears in them and I have it back in the TV instead. But when I leave Settings for watching TV this setting disappears.
What am I doing wrong ?
/hans peter
By starwoodtech
- 2 replies
- 5,640 views
- 4 replies
- 33,274 views
- 2,651 views
- 6 answers
- 24,129 views
Robin S
Is there a special trick to login to a Google account with webos? I got an LG CX but I'm not able to login. After I insert my credentials I see a terms of service screen with a disabled "agree" button. When I click on "later" the only other option I'm redirected to the login screen.
What can I do?
