LGTV 05.30.10
By Arthur
It would be nice to have an ability to play video (not only?) content from folder in shuffle mode.
Thanks.
By AVTech
I have been in hi end AV technology for years and I have purchased a ThinQ "smart" TV. After finally finding a way to stop the ridiculous loud static start up now I want to find a way to have the TV start at an installed app (Google TV etc.) instead of the unused antenna or HDMI input. It seem this would be the default if not just an option on a smart TV when actually using installed apps. Have I been missing something or is this some bizarre epic fail?
By Maksim Rabinovich
I have a rooted LG C1. Is it possible somehow to read data from the light ambient sensor? I tried searching in /dev, /proc/, sys/bus, but there's a lot of clutter in there.
By Cedric
My TV (49SM8100) is asking for firmware upgrade, but I would like to have to positive returns before upgrading it.
Did any of you upgraded it without problem ?
Ced
PS : I still can remember two upgrades ago, when the new firmware broke the Quick access key... I also have see two users with two different TV models which have been bricked after the update.
Jim Mo.
Every time I turn on my TV all the apps pop up....If this is by design, I want to know how to turn that feature off. If not by design I want to know how to fix it.
