HBOMAX
@bdv
This is ONLY an LG TV WebOS enthusiasts peer-to-peer forum, and has NO direct connection or affiliation with LG, the manufacturer, and has NO control or ability to ask or lobby for solutions or fixes.
If you feel strongly about the lack of APPS (or a specific APP) in your country, raise a support ticket with LG in your country, documenting your concerns and "wish-list".
    • By rphillips068
      Hi All,
      What is the latest with HBOmax and LG?
      Are they playing nice in the sandbox or is HBO still not have its act together?
      I have a SK8000PUA 4K HDR Smart LED SUPER UHD TV w/ AI ThinQ
      Thanks.
      Rob
    • By Gshep1
      I set up airplay on our LG smart TV and it works just fine for most things. However, when I try to mirror something from HBO max from the iPad, I get sound on the LG TV but no picture. It’s the same for anything I try to mirror from HBO max, not just a particular show. This is the first time I’ve run across this. Most services mirror just fine. Any ideas? Thanks.
    • By James M DeLuca
      I qualify for HBOmax by virtue of subscribing to HBO on DirecTV.
      I wanted to be sure that I should have DirecTV provide the app instead of LG.
      Thank You in advance.
