RichardD Posted February 15, 2021 Posted February 15, 2021 Hi, Mi problem if finding out how to pop iup a small (DVE) window somewhere over the main window. For example. When HDMI-1 is selected, I want to display HDMI-2 in a small window somewhere on top of the original (HDMI-1) screen. Can/How do I do this. Happy to use an API. Thanks in advance Rich Quote
0 td47 Posted February 22, 2021 Posted February 22, 2021 @RichardD Are you asking as a normal user, or as a developer? If the first one, there are NO options to mess with the settings that you have to do this, it is what it is. If you are a developer, then you should be on the official LG developers forum or group, and have a Developer account, and a test TV set up in developer mode to try/test your dev software. 1 Quote
0 RichardD Posted February 22, 2021 Author Posted February 22, 2021 I am happy to try teh developer side. Thanks for your help R Quote
RichardD
Thanks in advance
Rich
