aspect ratio
Hello my tv is connected to an XBOX one and is in the aspect ratio "16'9" this is not the aspect ratio I would like as it does not fit my tv and makes it all  blurry so I can not read anything and when I go to aspect ratio it give me every other option except "full wide" which is the exact one I need. Whenever I go to click on "full wide" it moves me to the one right underneath it . I do not know how my tv ended up doing this , but it has been like this for almost a week. And whenever I search up how to fix it ,"resolution" is the only thing that comes up and apparently I need to change that but whenever I watch a video on how to do that its either, a newer version of the LG tv or has more options than my tv . Then I have no way of fixing it , I would love some help from literally anyone who knows how to fix this as it is getting quite annoying lol.        model no : 26LH2000-ZA        product code ; 26LH2000-ZA.CEKGLHO        power ; 100-240V~50/60Hz 1.1A(110W)        (SERIAL NO. :002TZSC29654)            (manufactured : february 2010)
does anyone know how to fix it
@devon That 11 year old TV was last updated with firmware on 2011!! That is way behind current technology,  so you are unlik;ey to get a fix.
If it DID ever work, I can only suggest you try doing a "factory reset" (reset to default settings) and try it again.
    • By Cody94549
      With a Curved Screen and a 240Hz Refresh Rate, LG’s New Gaming Monitor Helps
      Create an Expansive and More Responsive Gaming Environment
      SEOUL, May 10, 2023 — LG Electronics (LG) has launched its newest UltraGear gaming monitor (model 49GR85DC), a curved 49-inch display with a 32:9 aspect ratio and an ultra-high 240Hz refresh rate. Like having two 16:9 monitors side by side, the impressive new model delivers the silky-smooth gameplay and top-notch picture quality needed for immersive gaming experiences. While designed with gamers in mind, the 49GR85DC is also suitable for productivity or viewing content thanks to its advanced multitasking functionality and extra-wide screen.
      Featuring a 49-inch Dual QHD (5,120 x 1,440) resolution panel with a 1000R curvature, LG’s new UltraGear gaming monitor provides sharp, vibrant images that fill the user’s field of vision. The combination of the monitor’s generous screen width and 240Hz refresh rate1 helps create an expansive and more responsive game environment – making titles feel more real and dynamic. VESA DisplayHDR 1000 certified, the 49GR85DC also has a 3000:1 contrast ratio and a 1000-nit peak brightness2, producing vivid colors and deep, nuanced blacks. With its three-sided, virtually borderless design, the monitor enables users to stay focused as they battle their opponents or explore their favorite virtual worlds.
      Not just for gaming, the 49GR85DC offers an array of multitasking features that let users take full advantage of its elongated 32:9 aspect ratio screen. The new UltraGear supports Picture-in-Picture (PIP) and Picture-by-Picture (PBP) modes. PIP mode lets users display content from a second connected device in a floating window, while PBP mode allows them to work with multiple open windows at the same time by conveniently dividing the screen into two discrete sections.
      Important for users who enjoy PC and console gaming – and useful for multitasking as well – the new monitor provides connectivity via DisplayPort 1.4 and HDMI 2.1, both of which let users enjoy smooth gaming at 240Hz in Dual QHD resolution. Additionally, the curved UltraGear enhances the gaming experience with its LED Hexagon backlighting and support for DTS Headphone:X; an advanced audio solution that provides outstanding three-dimensional sound via wired headphones.
      “As the gaming monitor market continues to mature and grow, so too does the demand for expansive displays offering high refresh rates and superb picture quality,” said Seo Young-jae, senior vice president and head of the IT business unit of LG Electronics Business Solutions Company. “Designed for gaming, but equally suited to multitasking, the new LG UltraGear is a versatile, premium display solution that shows our commitment and ability to satisfy the diverse needs of today’s consumers.”
      Now available in the U.S., the new UltraGear gaming monitor will be launched in key markets throughout Europe this month and in Asia later this year.
      Key Specifications:
      LG UltraGear Gaming Monitor (49GR85DC)
      Display Type VA (Vertical Alignment) Screen Size 49-inch Aspect Ratio 32:9 Resolution DQHD (5,120 x 1,440) Refresh Rate 240Hz1 Color Gamut DCI-P3 95% (typ.) Contrast Ratio 3000:1 Brightness 1000nit (peak)2, 450nit (typ.)
      Response Time 1ms Gray-to-Gray (GtG) Curvature 1000R HDR VESA DisplayHDR 1000 Connectivity HDMI 2.1 x 2
      DisplayPort 1.4 x 1
      USB 3.0 x 1 Upstream
      x 2 Downstream
      4pole H/P out (DTS HP:X) Picture-in-Picture, Picture-by-Picture
      Yes Stand Tilt: -5 to + 15°
      Height: 110mm
      Swivel: ± 15˚
      Pivot: Not Available  # # #
      1 Gaming at 240Hz in Dual QHD resolution requires a PC with a graphics card that supports both HDMI 2.1 and DisplayPort 1.4.
      2 HDR peak brightness guaranteed.
    • By Jean Fiorin
      Good Morning, There is a recommended minimum distance between the TV and the viewer. I bought an LG OLED C155 last month and it is uncomfortable from a distance. It was my mistake. I bought it without worrying about visual comfort. Is it possible to reduce the screen's usable area to simulate a screen size TV of 48 inches or less, accepting the black borders that would be created? It would be something similar to a custom aspect ratio. The idea would be to be able to simulate a smaller screen size than the purchased equipment. other-bigger->65->55->48->other-less
    • By ABitencrypted
      I have a OLED65C9PLA and just updated the ITV Hub app to ITVX.  The app runs but the picture has the wrong aspect ratio and is displayed on the right two thirds of the screen. Any ideas?
    • By Tomo
      Hello,  I have a video stream with 4:3 aspect ratio, how can I transform it to  16:9 ratio in my application with JS or CSS ?
      I tried using object-fit, transform etc.
