Firmware 05.05.70
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By сергей фролов
By SailorMoon
Vadim Kostylev
I am on [05.05.90] - how can i downgrade to older firmware and where an i download version 05.05.70 for 55UB850V
